Surface Pro keeps going to sleep every 1-2 minutes of being idle
2013-04-14T03:29:09+00:00
Love the idea behind the Surface Pro, but been having software and hardware issues lately. One of the software issues I've been experiencing is that when my Surface Pro first goes to sleep after a restart and I wake it up, it then begins going into sleep mode every like 1-2 minutes of being idle. I noticed this when reading some news on the internet.
I double checked my power options I have my current power plan (based off Balanced) set to put my Surface Pro to sleep (while plugged in) after 30 minutes of being idle!
Anyone know what's causing this problem? Is this another OS bug in Windows Ei8ht? I've avoided contacting the Surface support team cause every time I've contacted them about technical problems like this, their only solution is to perform a system refresh.
2014-09-12T04:37:53+00:00
go to desktop mode, go to screen saver, if it says blank, 1 minute, change it to none. it fixed mine SP3, Same issue.
66 additional answers
    2014-06-25T21:52:18+00:00
    My surface pro 2 keeps going to sleep every 1-2 minutes. I checked my settings for this and the problem still persists. I work on my computer daily but I am in no way a computer genius- therefore I am trying to find a safe download to correct this as the explanations I have read are apparently only understood if your a "computer programmer. :). I am not sure how to create files In the system etc. please help
    2014-03-18T09:44:37+00:00
    Is there already a fix found for this?
    2014-01-17T23:24:44+00:00
    So nothing I tried worked and this was giving me the heebie jeebies having to login so often so I have a temporary workaround for those struggling with the problem. Just play a video clip on repeat with the sound in the media player muted and the window minimised. It works a treat for me and not I can get on with my work until a real fix comes along.
    2014-01-17T03:31:53+00:00
    17th January and this same ugly bug has raised its head again. It is making my surface pro almost impossible to use. I have tried everything in this forum and none of it worked. This needs to be fixed now. A critical bug like this should not be around for this long.
