Surface Pro 7 randomly freezes while using the Zoom app
2020-03-27T22:55:07+00:00
Brand new surface pro for about 2 weeks and I've experienced some random freezes while using the Zoom teaching app. For some reason, each time this happens the audio continues to work but nothing on the surface screen or keyboard is responsive and I'm forced to shutdown and restart each time. Support recommended that I run a recovery tool but that didn't do anything to fix my problem. Does this sound like more of a Zoom problem or a surface problem?
Anyone else have a similar issue and fixed it?
    2020-10-03T14:45:56+00:00
    I have similar issues - had not connected it to zoom though.
    2020-10-03T05:55:01+00:00
    Hello Fellow Warriors: I originated this thread. I have seen several interesting solutions to the original problem.
    1. Upgrading Surface Pro processor. I bought my Surface Pro at Costco...big mistake. It came with an inferior processor.
    2. Unchecking Zoom acceleration features in settings.
    As a result, I will not purchase Microsoft products if I can find an alternative.
    I wish you all well.
    JuniorNelson
    2020-10-03T03:02:38+00:00
    My IT guys tried all of that. We tested daily for weeks. Didn't help. i5 processor
    2020-10-03T02:52:03+00:00
    This is helpful. Would it help if I got the i7 processor with 16 GB?? I have i5 8 GB now. Im planning on going back to the store tomorrow morning to decide what I should do.
    I want to be able to write on the screen
    zoom or google meet with NO issues
    use microsoft office to make word documents
    record lessons using screencastify
    ipad pro may not be my solution. I know it cant do screencastify.
    Im literally losing sleep over this
    2020-10-03T02:24:40+00:00
    The issue is certainly with Surface Pro 7, which does not have a fan to cool down the CPU or GPU, unless you got the top of the line model with Intel i7-1065G7 (https://surfacetip.com/is-surface-pro-7-fanless/).  It seems the computer would freeze if the CPU or GPU overheats, which can occur not only when using Zoom but also when running some other computation-intensive applications for a long time. If you get a different computer with active cooling with a CPU fan, it probably would not have a similar issue, especially if it has a dedicated GPU. Not sure why the "genius engineers" at Microsoft decided to remove the CPU fan in Microsoft Surface to render this $1000+ machine to work worse than a $200 tablet or a 10-years old computer.
    If Zoom is the only issue, it is not hopeless as long as you can manage to reduce the work of the GPU. I have not had issues recently after doing the following:
    1. Disable hardware acceleration
    2. Change to use Direct3D11 in Video Rendering Method (the default is Direct3D12, which makes the GPU work harder)
    3. Uncheck "Enable HD" in the Video setting so that the CPU/GPU will spend less effort in processing the video
    Try to logout and log back in after making the changes (or kill Zoom in Task Manager and then restart Zoom)
    Of course, it also depends on the CPU you have. Mine is i5-1035G4. Not sure whether it would work with the i3 processor.
    I've got the i3 with 4gb of RAM and I've done pretty much the same and it's been working for me since I did it.
    Something else that I do is make sure it not plugged into the charger during the call.  That's to help with the heat as well.
