The issue is certainly with Surface Pro 7, which does not have a fan to cool down the CPU or GPU, unless you got the top of the line model with Intel i7-1065G7 (https://surfacetip.com/is-surface-pro-7-fanless/).
It seems the computer would freeze if the CPU or GPU overheats, which can occur not only when using Zoom but also when running some other computation-intensive applications for a long time. If you get a different computer with active cooling with a CPU fan,
it probably would not have a similar issue, especially if it has a dedicated GPU. Not sure why the "genius engineers" at Microsoft decided to remove the CPU fan in Microsoft Surface to render this $1000+ machine to work worse than a $200 tablet or a 10-years
old computer.
If Zoom is the only issue, it is not hopeless as long as you can manage to reduce the work of the GPU. I have not had issues recently after doing the following:
- Disable hardware acceleration
- Change to use Direct3D11 in Video Rendering Method (the default is Direct3D12, which makes the GPU work harder)
- Uncheck "Enable HD" in the Video setting so that the CPU/GPU will spend less effort in processing the video
Try to logout and log back in after making the changes (or kill Zoom in Task Manager and then restart Zoom)
Of course, it also depends on the CPU you have. Mine is i5-1035G4. Not sure whether it would work with the i3 processor.
