Great fix, worked for me! Not sure of the origin of the low brightness/no adjustment issue however...would be good to know.
Surface Pro 7 display brightness does not chage
Anyone has the same issue as me?
When I change brightness with keyboard it does change to 30-50% only (no visible change).
When changing in side swipe, with touch it allows me to change 0%-100% (no visible change)
I tried with nigh mode off... no change
Tried windows setting ... no change
Ambient light On/Off... no change
Can anyone help?
Marek
2020-10-20T16:53:21+00:00 -
2020-10-18T13:41:40+00:00 Hello, if you check the surface pro 7 update history, in the January 30th update there is one update that should have fixed the problems with display brightness. Please check that you have installed all the latest updates and if so, run the surface diagnostic toolkit to make sure no system files corruption are causing your issues.
Surface – System - 21.28.139.0 Surface Integration – System devices 21.28.139.0<br><br><ul><br><li><span>improves display brightness scenarios and improves integration between system services.</span></li></ul> -
2020-09-04T15:32:36+00:00 This helped me fix the problem, thanks a bunch!
2020-08-10T00:46:02+00:00 After restarting my surface the brightness thing is no longer there so i cant change the brightness anymore
2020-08-10T00:34:08+00:00 how do you reinstall the display driver?
