Surface Pro 7 display brightness does not chage
2019-11-21T22:50:00+00:00
Anyone has the same issue as me?
When I change brightness with keyboard it does change to 30-50% only (no visible change).
When changing in side swipe, with touch it allows me to change 0%-100% (no visible change)
I tried with nigh mode off... no change
Tried windows setting ... no change
Ambient light On/Off... no change
Can anyone help?
Marek
    2020-11-22T12:12:00+00:00
    Thanks for the tip. I recently bought a surface Pro and have been struggling with the brightness.
    2020-11-17T15:58:43+00:00
    thank you very much... was trying so much things there but nothing worked . finally this worked.thanks man!
    2020-10-23T18:42:06+00:00
    i could kiss you this has been  worst week
    2020-10-22T16:01:43+00:00
    Thanks for the response.  Hopefully it doesn't happen again, but if it does and this simple fix doesn't work i'll re-post.
    2020-10-22T12:33:06+00:00
    I tried this for a different issue I had with the display but it didn't work the second time around neither did it work for this so this might only be a 1 time use solution.
