Surface Pro 5 fan stops working after installing firmware update
2019-01-03T11:40:57+00:00
Hi
I have a Surface Pro 2017, i7, 8GB, 256 but in recent month the fan is not turning on in any working condition. previously I can heard easily the sound of the fan but now its not turn on anyway.
2019-02-07T02:12:41+00:00
Hi saiedbaran,
Thank you for your feedback. We understand your concerns and have been investigating. An update has been flighted to Windows Insiders that we believe addresses this problem and are evaluating that update for release on Windows Update.
Please stay tuned and continue to check for Surface and Windows Updates to ensure your device has the most current firmware and software available.
Note: Marking as "Answered" to raise visibility for now. We will update this response once the fix has been published.
Greg
58 additional answers
    2019-01-21T07:14:41+00:00
    I'd say firmware versions won't allow being overwritten by any older version. Any tinkering would likely increase the chance of permanently bricking the device and void warranty...
    As this faulty firmware has been available for at least 2 months, I'd guess either no one at Microsoft with SP5 i7 participates with release previews, doesn't use them for compiling software or any other CPU intensive tasks, or both 🤔
    2019-01-21T00:34:16+00:00
    Jan, think logically, how is downgrading to 1703 going to solve a firmware issue? Microsoft is likely going to send you a replacement, however I'm tempted to wait a bit longer until they release a newer firmware to fix the issue, since this issue isn't hardware or operating system related for that matter.
    In the mean time I'm using an USB fan pointed towards the back of the device and this keeps sufficiently cool. That saves the hassle of creating a backup and reinstalling it on a new device.
    Thankfully someone else encountered this issue!
    Would it be possible to somehow extract the Surface Pro 5 firmware from another surface pro 5 i7, and inject/install it onto the current insider build/device?
    Since as you mentioned, perhaps someone in Microsoft accidentally replaced the firmware to those of a surface pro 4.
    2019-01-20T23:27:06+00:00
    I have this exact same issue.
    After installing 1809 insider edition, the fan completely stopped working.
    Currently running 2 fans on the rear of my surface pro 5 i7.
    2019-01-17T21:48:58+00:00
    I mention the recovery image because if you go to exchange in/out of warranty,
    support will ask you to reimage, just in case it is not firmware and can be
    fixed in software by reimaging.
    I can't get Microsoft to acknowledge "a known issue" with any firmware delivered
    only to Insiders, and I don't seem to have access to the Feedback Hub reports so
    I can't see if Microsoft has acknowledged there either.
    Believe me, I DO understand the pain. My replacement SP2017 LTE i5 (different
    issue) just arrived today.
