Surface Pro 5 fan stops working after installing firmware update
2019-01-03T11:40:57+00:00
Hi
I have a Surface Pro 2017, i7, 8GB, 256 but in recent month the fan is not turning on in any working condition. previously I can heard easily the sound of the fan but now its not turn on anyway.
2019-02-07T02:12:41+00:00
Hi saiedbaran,
Thank you for your feedback. We understand your concerns and have been investigating. An update has been flighted to Windows Insiders that we believe addresses this problem and are evaluating that update for release on Windows Update.
Please stay tuned and continue to check for Surface and Windows Updates to ensure your device has the most current firmware and software available.
Note: Marking as "Answered" to raise visibility for now. We will update this response once the fix has been published.
Greg
58 additional answers
    2019-01-17T13:44:18+00:00
    Yes, thanks Barb.
    Downloading the recovery image now for 1803 and will see if that makes a difference. Will post back to the forum either way.
    2019-01-17T13:41:08+00:00
    Thanks Barb,
    Going to give the USB recovery a try.
    I will make a post tonight if the recovery helped :)
    2019-01-17T13:28:12+00:00
    As I said in my reply to Nortnern Cyclist, I'd reimage from a downloadable
    recovery image and stress test to see if the fan turns on or not. Then update to
    1809 and test some more. If you still have issues and are experiencing a shut
    down with the thermometer icon, consider an exchange.
    2019-01-17T13:24:32+00:00
    >Do you think that doing a clean Windows 10 install on the machine would get it working again? I'd rather have fans and just run the standard Win 10 Pro if that's an option. Not convinced it would myself if it's a firmware issue (or hardware).
    Get the official downloadable recovery image from
    https://support.microsoft.com/en-us/surfacerecoveryimage  and completely wipe
    and reimage. Then update to 1809 and all the latest drivers and firmware through
    Windows Update. Then stress test as best you can to see if the fan starts and if
    it shuts down with the thermometer icon.
    If you still have these issues and you are in the US, you should go to the
    closest physical retail Microsoft Store
    https://www.microsoft.com/en-us/store/locations/find-a-store - outside the US,
    contact support
    https://support.microsoft.com/en-us/help/4051701/global-customer-service-phone-numbers.
