Surface Pro 5 fan stops working after installing firmware update
2019-01-03T11:40:57+00:00
Hi
I have a Surface Pro 2017, i7, 8GB, 256 but in recent month the fan is not turning on in any working condition. previously I can heard easily the sound of the fan but now its not turn on anyway.
2019-02-07T02:12:41+00:00
Hi saiedbaran,
Thank you for your feedback. We understand your concerns and have been investigating. An update has been flighted to Windows Insiders that we believe addresses this problem and are evaluating that update for release on Windows Update.
Please stay tuned and continue to check for Surface and Windows Updates to ensure your device has the most current firmware and software available.
Note: Marking as "Answered" to raise visibility for now. We will update this response once the fix has been published.
Greg
58 additional answers
    2019-01-16T22:24:55+00:00
    I seem to have the same problem, I think it started in late December. I wasn't aware of the lack of fan at first, but noticed the sluggish performance. Today the machine shut down with a large 'thermometer' icon on screen because it had overheated.
    I really hope this can be fixed by a firmware update and doesn't need hardware replacement.
    My entry on the Feedback Hub
    https://aka.ms/AA3ti54
    2019-01-12T22:12:53+00:00
    Same problem here. From my contact with support they suggested a replacement, but since my Surface is out of warranty I will have to pay for that.
    I will wait a couple months to see if they release a new firmware fixing it. But I think they will have a huge problem if this keeps happening to insiders.
    2019-01-09T16:02:37+00:00
    Please upvote here: https://aka.ms/AA3rjyd
    2019-01-09T14:02:35+00:00
    I already did it and its so important for me because now my surface becomes useless
