Surface Pro 5 fan stops working after installing firmware update
2019-01-03T11:40:57+00:00
Hi
I have a Surface Pro 2017, i7, 8GB, 256 but in recent month the fan is not turning on in any working condition. previously I can heard easily the sound of the fan but now its not turn on anyway.
2019-02-07T02:12:41+00:00
Hi saiedbaran,
Thank you for your feedback. We understand your concerns and have been investigating. An update has been flighted to Windows Insiders that we believe addresses this problem and are evaluating that update for release on Windows Update.
Please stay tuned and continue to check for Surface and Windows Updates to ensure your device has the most current firmware and software available.
Note: Marking as "Answered" to raise visibility for now. We will update this response once the fix has been published.
Greg
58 additional answers
    2019-01-25T20:54:06+00:00
    I can send you a private twitter message with the case number. I followed you a few minutes ago.
    In Dutch this was said:
    "Er is mij verteld dat als u op de Release Preview branch gaat, u een aantal voorwaarden moet accepteren, waaronder het feit dat u accepteerd dat er eventuele problemen of schade kan komen door middel van problemen in de preview build."
    Translated into English:
    "I have been told that if you go to the Release Preview branch, you must accept a number of conditions, including the fact that you accept any problems or damage through problems in the preview build."
    There has been an update today, I received a call by the support team and they forwarded the call to the business support department. I explained the situation and they immediately apologized, this should have never been said. Hope to hear back from them beginning next week with an adequate proposal.
    Thanks for willing to assist
    2019-01-25T14:44:00+00:00
    Case #?
    2019-01-25T12:59:24+00:00
    Breaking news: the support guy who I'm speaking with right now has been instructed to tell me that I forfeited to any support since I accepted terms and conditions of the insider program...
    Imagine this:
    • You have a device from Microsoft
    • You join the insider program to make sure the apps you're working on still work in future versions of Windows
    • You receive a firmware update through Windows Update which causes a problem with your device
    • The device malfunctions due to that
    • You don't get any support since you're part of the insider program
    If word gets out then NOONE is joining the insider program anymore, so Microsoft: get ready to invest in your own test department, with such conditions I'm not willing to do this for free anymore, breaking my Surface device and then telling me it's my own fault????
    Exactly my thoughts.
    2019-01-25T12:48:35+00:00
    Imagine this:
