Surface Pro 7 Front Camera Not Working
2019-10-29T19:25:09+00:00
I'm not sure when it started, since I hadn't used the front camera on the device at all, but today I noticed in the Device manager that the "Surface Camera Front" has an error:
This device cannot start. (Code 10) STATUS_DEVICE_POWER_FAILURE.
Sure enough, upon opening the camera app, it acts as though I only have the back camera installed.  I am predictably unable to bring up the front camera.
Is there possibly a driver issue, or is this a hardware flaw?
Thanks!
**Edit**: Problem persists through reboots, disable/reenable, troubleshooter, etc.  Notably, I realized the front camera worked for at least the first hour that I had the device, since it shows you the camera feed when setting up Windows Hello.
Surface | Surface Pro | Sound and camera
    2021-03-12T19:36:04+00:00
    COPY-PASTE:
    " Hi Guys !
    I found a solution that 've worked for me after hours and hours...
    ( I had my 3 camera with the yellow exclamation point in the devices panel (check "see hiden devices" in the menu bar) and " camera device power failure " in the settings of the cameras)
    The solution:
    I've just delete the first "Intel Control Logic" in "System Devices" and checked to delete also the driver !
    Then restart and voila !
    Please upvote this message if it worked for you too !
    Jeff "
    2021-03-10T06:24:26+00:00
    Hi Guys !
    The solution:
    Jeff
    Thanks!! Finally it is fixed!
    2020-08-20T02:19:35+00:00
    The same thing happened to me after a recent Windows update.  Here is the solution that finally fixed it for me:
    • Open "Device Manager"
    • Under “System devices”, there are 3 entries for “Intel Control Logic”.  Right-click the first (topmost) “Intel Control Logic” in the list, then select “Update driver”
    • Click “Browse my computer for driver software”
    • Click “Let me pick from a list of available drivers on my computer”
    • Select the 12/16/2019 version of the driver (42.18362.3.196)
    • Click “Next”
    • Click “Close”
    • Click “Yes” to restart the computer
    Thank you for your information and support. I have returned the machine to the factory for overhaul, and the problem has been resolved.
    2019-10-30T17:21:09+00:00
    Hi, thank you for getting back to us. We suggest a Fresh Start. However, it removes third-party antivirus software and all apps that don't come standard with Windows. You can do this without losing your personal files.
    Fresh Start:
    • (Optional) Back up your files. We recommend this precaution, even though Fresh start keeps your data intact.
    • In the search box on the taskbar, type Windows Security, and then select Windows Security in the list of results.
    • Select Device performance & health.
    • Under Fresh start, select Additional info, and then select Get Started to start the process.
    If issue persist, we highly recommend that you Reset the device using a USB Recovery Image. This option reimages the entire device, including the partition on the hard drive. It is the most complete form of reset and you need to back up your personal data. You must have 16GB/32GB of Flash Drive and it must be formatted into FAT32 prior to downloading the Recovery Image. I am providing you the instructions on how to create a USB recovery drive for your Surface.
    How to Download, Create and Use a USB recovery drive
    To download the Recovery Image:
    • You'll need a PC running Windows 7 or later.
    1. Visit the page at http://www.surface.com/support/warranty-service-and-recovery/downloadablerecoveryimage
    2. Sign in with your Microsoft Account (this is the email address we asked you for at the start of the call)
    3. From the list of Surface devices available, select the device that you need a recovery image for
    Please note that while you will only be presented with devices that are currently registered on your account, you will also be presented with the option to get an image for a different type of device. If you try to use this option, you will be prompted to enter the serial number for that device 4. Download the recovery image using the button on the page 5. When the download bar pops up at the bottom of your screen, save the file in a location you will be able to find it.
     Format USB Drive:
    • Note: Formatting a recovery drive will erase anything that is already stored on your USB drive. Make sure to transfer any important data from your USB drive to another storage device before using it to create a Surface USB recovery drive.
    1. Insert your USB drive into the USB port of your PC.
    2. From the desktop, open File Explorer
    3. Tap and hold or right-click on the USB drive and choose Format
    4. Select FAT32 as the file system and enter a Volume label to name the USB drive, such as RECOVERY, and then tap or click Start
    5. Tap or click OK to erase the contents of the USB drive
    6. Tap or click OK when the format is complete
    Create a recovery drive:
    1. On your Surface or PC, open recovery image that you downloaded by double-clicking it or right click then select Extract and then Extract all.
    2. Select the USB drive you formatted earlier for the location and click Extract.
    Use a USB recovery drive to reset your Surface (Cannot load Windows):
    1. Turn the Surface off by pressing the power button
    2. Insert the USB recovery drive into the USB port
    3. Press and hold the volume-down (-) rocker
    4. Press and release the power button
    5. When the Surface logo appears, release the volume-down (-) rocker
    6. Surface will start the recovery software on the USB recovery drive
    7. When prompted, choose your language options and keyboard layout
    8. Select Troubleshoot
    9. Select Recover from a Drive. Choose Remove Everything and Fully Clean the Drive. Recovering this PC.
    10. If prompted, select Repartition the drives
    11. If prompted for BitLocker Key, tap Skip this Drive
    Please keep us posted.
    Regards,
    KarenJune_F
    2020-04-03T15:40:24+00:00
    I would like to also know if there are a number of warranty exchanges for this issue without spending the hours to go through all the gyrations suggested by this thread?  Unfortunately, until the COVID19 issue, I didn't use my camera until the warranty period probably expired for my machine.  But what is Microsoft doing for this?
