same here, done all this twice already and still the camera won't work, very disappointing.
Surface Pro 7 Front Camera Not Working
I'm not sure when it started, since I hadn't used the front camera on the device at all, but today I noticed in the Device manager that the "Surface Camera Front" has an error:
This device cannot start. (Code 10) STATUS_DEVICE_POWER_FAILURE.
Sure enough, upon opening the camera app, it acts as though I only have the back camera installed. I am predictably unable to bring up the front camera.
Is there possibly a driver issue, or is this a hardware flaw?
Thanks!
**Edit**: Problem persists through reboots, disable/reenable, troubleshooter, etc. Notably, I realized the front camera worked for at least the first hour that I had the device, since it shows you the camera feed when setting up Windows Hello.
Surface | Surface Pro | Sound and camera
2019-11-30T05:25:07+00:00 -
2021-01-21T16:30:55+00:00 The same thing happened to me after a recent Windows update. Here is the solution that finally fixed it for me:
- Open "Device Manager"
- Under “System devices”, there are 3 entries for “Intel Control Logic”. Right-click the first (topmost) “Intel Control Logic” in the list, then select “Update driver”
- Click “Browse my computer for driver software”
- Click “Let me pick from a list of available drivers on my computer”
- Select the 12/16/2019 version of the driver (42.18362.3.196)
- Click “Next”
- Click “Close”
- Click “Yes” to restart the computer
This worked for me. Well, at least for now. I didn't have a 2019 version but I did have a 2018 version and that seemed to do the trick. Thanks for the fix IT Troy.
2020-11-22T16:26:45+00:00 The same thing happened to me after a recent Windows update. Here is the solution that finally fixed it for me:
- Click “Next”
- Click “Close”
Thank you for your information and support. I have returned the machine to the factory for overhaul, and the problem has been resolved.
I am greatly excited and most appreciative - this worked for me!
In actual fact, this is the only one of the scores of suggestions I got which worked for me.
In my case though, I did not have the "12/16/2019 version of the driver (42.18362.3.196)".
My Surface Pro 7 had two more recent versions (2020) of the driver; I selected the older one.
It worked like magic and in seconds!
I had spent hours troubleshooting from the previous night and was almost giving up. I'm grateful that I did not. Thanks so much.
2020-04-03T15:50:03+00:00 No, I spent HOURS on the phone with customer support trying to fix and no solution. They FINALLY sent me a replacement device and it happened again.
I found that when the device was trying to sign me in using facial recognition (which it failed repeatedly), it was screwing up the camera once I got logged in. I turned the facial recognition log-in option off and that seems to have fixed the problem.
Barb Bowman 80,810 Reputation points MVP Volunteer Moderator2019-11-30T10:20:15+00:00 Can you go into the UEFI and toggle the cameras off and then on and see if
anything changes?
- Shut down your Surface and wait 10 seconds.
- Press and hold the volume-up button on your Surface and at the same
time, press and release the power button.
- The Microsoft or Surface logo appears on your screen. Continue to
hold the volume-up button. Release the button once the UEFI screen appears.
