Surface Pro 7 Front Camera Not Working
2019-10-29T19:25:09+00:00
I'm not sure when it started, since I hadn't used the front camera on the device at all, but today I noticed in the Device manager that the "Surface Camera Front" has an error:
This device cannot start. (Code 10) STATUS_DEVICE_POWER_FAILURE.
Sure enough, upon opening the camera app, it acts as though I only have the back camera installed.  I am predictably unable to bring up the front camera.
Is there possibly a driver issue, or is this a hardware flaw?
Thanks!
**Edit**: Problem persists through reboots, disable/reenable, troubleshooter, etc.  Notably, I realized the front camera worked for at least the first hour that I had the device, since it shows you the camera feed when setting up Windows Hello.
Surface | Surface Pro | Sound and camera
    2021-05-31T10:07:26+00:00
    Hi I did this and turned on and off my rear and front cameras, my pc restarted and I opened camera. The button to rotate the camera to the front didnt appear and still doesnt appear. Please help. I tried joining several calls and meetings and when i on my camera my face isnt seen. Its blacked out.
    2021-05-27T15:24:46+00:00
    This was the only solution that worked for me, on my Surface Pro 4.
    I updated several drivers with IOBit Driver Booster Pro since it does a better job of updating drivers (not in the case of Intel Control Logic) than Windows does.
    Since I updated a large batch of drivers after a fresh install of Windows 10, using IOBit Driver Booster Pro, and then encountered the issue again after just re-installing Windows, I suspected the program was the issue.
    In reality it was not, it did what it is supposed to do, however, this particular driver just broke the Cameras on the Surface Pro 4.
    I am extremely happy to have found this solution posted by @Jeff_78
    He was the only one that offered a viable solution, well, for me.
    The following words will be tags to be indexed by search engines in the future;
    Surface Pro Camera not working
    Surface Pro Camera issue
    Surface Pro Camera problem
    Surface Pro Camera driver not working
    Surface Pro Camera driver issue
    Surface Pro Camera driver problem
    Surface Pro driver exclamation point
    Surface Pro Camera driver update
