On Sat, 27 Sep 2014 16:42:51 +0000, A G Williams wrote:
>>I'm getting 70mb/s from my desktop
>>I'm getting 10mb/s from my laptop on 2ghz
>>I start with 13mb/s on 5ghz then it dropped down during the test until it finished at <2mb (I htink it was 230k)
Please go to www.speedtest.net using ONLY your Surface Pro 3
go once with the SP3 connected to the 5 GHz band, run the test, then select
Share this Result, then copy, then paste the result into a reply. It will look
like this: http://www.speedtest.net/my-result/3791825082
close your browser. connect to the 2.4 GHz band, go back to www.speedtest.net,
run the test, then select Share this result, copy and paste into a reply.
please include who your provider is and what speed tier you are on in the format
105/10. replaced 105 and 10 with what your speed tier is.
Barb
