The latest update made it worse for me. can't believe this is microsoft's top of the line flagship. it's like buying a ferrari that tops out at 60mph. That's fast enough for most use, but I suppose most of us here are above average users.
Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
2014-09-12T17:10:52+00:00 -
2014-09-12T16:39:47+00:00 >>I didn't see any replies from Microsoft in the regards to the latest firmware yet. Is another update on the way or Microsoft is considering this issue fixed?
I have no idea. MVP's/CM's don't work for Microsoft. We are volunteers. I have
no communications with the Surface team. We keep asking everyone we possibly can
at Microsoft about this. Answers and information just aren't forthcoming.
Barb
This comment wasn't directly directed to you.
Something tells me that SP4 might be out by the time they fix WiFi on SP3 ;-)
Barb Bowman 80,805 Reputation points MVP Volunteer Moderator2014-09-12T15:53:58+00:00 On Fri, 12 Sep 2014 15:43:54 +0000, DextsarII wrote:
>>This doesn't really help for people who want to use their Surface at work, trips, or anywhere else besides home. I personally refuse to even mess around with settings on my router. This thing should be working without me making changes because all other devices are working well.
Yes, I understand, and I'm not willing to travel outside MY home with my SP3
because of this issue. But for people who primarily use at home, this IS an
option. And it is one of two options right now. Alternatively you could purchase a mini
wireless USB adapter - see
or a lesser expensive "N" version.
My reply to the person with the Verizon router suggesting a newer router was
because that Actiontec is so old.
But again, I absolutely agree that no one should need to spend money, change
settings and that Microsoft should have fixed this before launching the product.
Barb
2014-09-12T15:43:54+00:00 On Fri, 12 Sep 2014 13:49:06 +0000, SurfacePro3User wrote:
>>As I wrote above, we purchased a Surface Pro 3 (i7-256GB) in the first couple of days of August, but unfortunately the Wifi device inside the tablet seems to be seriously malfunctioning to this day and after this week's firmware update.
>>While the hourly resets have stopped, the connection is running at extremely slow transfer rates -- sometimes much slower even than the slow "speed" described in the "Wi-Fi Status" window.
>>Compared to other laptops and devices in the same location the Surface Pro 3 is very slow. For example, the Surface Pro 3 shows 24.0Mbps, but the laptop (a 2005 Dell Vostro) was experiencing no issues and was running at 130 Mbps.
>>Our test network was a Verizon FiOS setup using the Actiontec MI424WR-GEN3I router in 802.11n only mode.
You've probably read all the complaints about slow speeds with the 2.4GHz band
in this thread.
There's really been no definitive comment from Microsoft on this issue, only
references to a better user experience with the latest September updates.
If it were me, I'd be livid, but I'd bite the bullet and get a really good ASUS
or Netgear 802.11ac router and run it in Access Point mode and attach it to a
port on the Verizon router. I'd specify separate SSIDs for 5 and 2.4GHz and
connect my SP3 to the new 5 GHz SSID.
the MI424WR-GEN3I is ancient in router years. Verizon will sell you a better
FIOS router for $75-$100 but you are better off with your own device.
I DO realize that the issue is with the SP3. But absent a fix from Microsoft and
the lack of specific comments on this specific issue from Microsoft, I'd
probably spend the money. This isn't a real answer to the lack of
attention/fixes, but it is the only thing I can suggest.
I can personally vouch for the Netgear R7000 and the ASUS RT-AC68U. There are
some cheaper routers that can be run in AP mode that may work ok, but I don't
have personal experience with them.
Barb
Barb Bowman 80,805 Reputation points MVP Volunteer Moderator2014-09-12T15:34:39+00:00 On Fri, 12 Sep 2014 13:49:06 +0000, SurfacePro3User wrote:
in this thread.
Barb
