Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
2014-06-21T05:48:07+00:00
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
    2014-08-12T21:02:31+00:00
    Well as a last ditch effort I did a total reset of the unit to factory config and installed the new 8/12/14 firmware update (and power-cycled, did a dance, yada yada) and no joy, still 3 mbps on the internal chipset and instantly goes to nearly 40 mbps with an external wifi dongle. Back it goes, damn shame.
    BTW for those whom the update worked I'd again suggest making sure that it works on more than just your home router before declaring the problem fixed... because the problem clearly isn'tfixed, given that I am testing on a brand new unit in purely stock configuration (other than the required updates) and it still doesn't function properly.
    2014-08-12T20:05:32+00:00
    I just got the update couple of hours ago, I installed the update, then rebooted and then shut down.  Then I changed my router's 5 GHz band to AUTO channel, I had it in the high band.  I prefer to have it in auto since every other gadget works just fine with it in Auto, the SP3 should too and it was not working so far.
    I then powered up the SP3 now with the latest firmware and so far approx. 2 hours it is good without any sign of slowing down as it did before, it is early so I will live with it for couple of days and report back.
    So far the transfer rates are holding at what they were, I moved several GB of data, some in multiple smaller files and some large 4-10 GB files and the results were the same, about 230 Mbps which is good enough for me.  As long as the Wi-Fi is stable and if it maintains this transfer rate, we are good.
    Thank You
    Just FWIW my WAPs are all wireless N so if yours seems to work with A or AC you might want to verify that it also works properly using N mode, so you won't get an unpleasant surprise when you are out roaming somewhere.
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2014-08-12T20:02:43+00:00
    Sounds "promising".. keep us posted.
    everything BUT the firmware has shown up here... I also keep checking
    http://www.microsoft.com/en-us/download/details.aspx?id=38826 but they haven't
    posted it there either.
    I got the System Firmware update, a bunch of misc. updates and the 171meg
    download, but not the individual firmware updates that are being rolled out
    "gradually".
    Barb
    Barb's Connected World Blog Reader Windows 8 App -
    http://apps.microsoft.com/windows/en-us/app/barbs-connected-world-blog/02f35769-52bf-461c-b1d5-06e54a58d298
    2014-08-12T19:55:47+00:00
    Out of curiosity, has anyone tested the throughput of a USB ethernet adapter? I am oddly experiencing the same throughput issue on both wifi and wired. The adapter i'm using is not the microsoft branded adapter, however I use these around the office when necessary and have no trouble with them normally.
    2014-08-12T19:52:26+00:00
    Thank You
