Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
2014-06-21T05:48:07+00:00
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2014-08-09T09:27:48+00:00
    On Sat, 9 Aug 2014 00:26:08 +0000, NicholasKasprinski wrote:
    |Why won't MS let us choose the preferred band on the wireless card?
    because that is not part of the 802.11 spec.
    Barb
    Barb's Connected World Blog Reader Windows 8 App -
    http://apps.microsoft.com/windows/en-us/app/barbs-connected-world-blog/02f35769-52bf-461c-b1d5-06e54a58d298
    2014-08-09T00:39:05+00:00
    It doesn't have to do with channels. The problem is that when the SP3 wakes up it automatically reverts to 2.4Ghz even though it was connected to 5Ghz. The only way to fix this is to all us to choose the preferred band like we can with any other wireless driver or to specify a different SSID for 2.4Ghz and 5Ghz. I don't want to set different names I like for my devices to be able to go between the two based on how far away from the router is.
    If it goes back to 2.4 is because it does not find the 5 Ghz. So we want to know why. So we need somebody to use different SSID for both bands and fixed channels. Just for testing purpose.
    2014-08-09T00:26:08+00:00
    2014-08-08T17:46:17+00:00
    On Fri, 8 Aug 2014 14:36:27 +0000, newpop1 wrote:
    |1) Channels are not specified, it is on Auto.  In my location there are no
    other WiFi stations around anyway and I do not like to tinker with channels,
    never had to before.
    Please test this. For me, the HIGHER channels always work best.
    Barb
    The bottom line he should try fixed channels and tell us the result.
  5. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2014-08-08T15:46:47+00:00
    Barb
