Hello, I am not sure why today the SP3 decided to disconnect from the WiFi every time I put it to sleep (tap on the power button) When I tap on the power button or press on the windows key, the WiFi shows disconnected and I have to manually reconnect to the WiFi router. In some instances I have had to reboot the SP3 in order for the network to even work.
As usual, all the other devices in the home are working just fine without issues.
I even tried rolling the wireless driver back to the 6/3 version and still no luck. This is something new and no software has been installed.
Why can't this be solved by now? bit frustrating not being able to even use it. Any other thing that I can do to make the WiFi work?
