Surface Book 2 audio - Crackling sound in Zoom meetings
2020-04-15T05:20:04+00:00
Hello Microsoft Community,
I am experiencing exactly same issue as highlighted in this post;
https://answers.microsoft.com/en-us/surface/forum/all/surface-book-2-microphone-starts-crackling-after/0f27fa1b-3bec-4927-8c5b-303522bad118
When I am in a Zoom meeting with 1 person it appears ok - but when a meeting with multiple attendees (hence higher CPU load) are in progress all of sudden other participants get loud crackling noise when I speak, and it has happened on a regular basis.
I have used both
  • the built in mic array, as well as
  • a separate Logitech USB headset & a Plantronics USB headset
but when the crackling jumbled sound starts to occur, it doesn't matter which mic I am using - and it continues on and off.
I have updated the drivers to the latest packages available, but the issue persists.
I have seen a post talking about unchecking "Enable audio enhancements - Signal enhancements" on Reddit
https://www.reddit.com/r/Surface/comments/3dgdkw/how_to_fix_audio_cracklingdistortion_on_surface/
but I don't see that option in my Surface Book 2 13" i5 model (with the latest Windows 10 patches)
However I do notice a checkbox with "Enable Hardware Acceleration". If I uncheck the box what would it do?
Regards,
Jihong
Surface | Surface Book | Sound and camera
    2020-07-18T23:09:37+00:00
    There is a fix.
    Follow the instructions to reinstall all of the surface drivers, then do a hardware reset. (Power + vol btn)
    Messing around with the audio enhancements does absolutely nothing.
    2020-07-18T23:01:27+00:00
    i spoke too soon, don't know if my default settings defaulted back but had a zoom call yesterday. was a mess. five time the listener complained about the audio. i'll go back an reinitiate all the fixes and see if anything works. this is pretty ridiculous that MS hasn't found a fix.
    2020-07-17T22:27:56+00:00
    I tried this in the morning with one person, and we still had problems.  They were not as bad.  I had already upped my bandwidth (have anywhere from 300 - almost 5000 mbps...  Before my husband had to get off his laptop, but not now.  My drivers are up-to-date.  It is better.
    Closing programs definitely helps.  I did have a few open today.  But, this is, after all, Windows, right?  Should be able to have some open.
    I do think it has to do with the microphone. I think we are on the right track, but that didn't solve my problem totally. So...someone asked before about a Reddit blog  about "Unchecking "Enable audio enhancements - Signal enhancements. Australiasquare indicated that  s/he didn't see that option.  but saw "Enable Hardware Acceleration" and wondered what unchecking that box would do. Did you try that?
    Under Speaker Properties, Advanced, Hardware acceleration, should I unclick the following:  "Allow hardware acceleration audio with this device."
    Thanks for any insights.  Meryl
    2020-07-17T06:35:47+00:00
    Think I may have solved this.
    In Zoom, there is a setting for allowing the computer to adjust the mic level.
    When I turn this off, I no longer have the problem.
    I am guessing the mic is quite sensitive and starts pickling up more and more souind if you quiet for a period, then when you speak it's way too loud and distorts terribly.
    You will find this in Zoom settings, audio, under mic level.
    Thank you!
    I've changed the setting and will try it out in a meeting soon!
    2020-07-17T06:08:25+00:00
    Thank you. Originally i downloaded all current drivers, a few times. However, that was about two months ago. I haven’t had any complaints since but i have had only one on one zoom meetings and no workshops or classes (conducted by me) since the problem.  However, i was getting complaints before even on one on one meetings. Not now.
