Fixed with today's update. Thanks, MS!
NOTE: I had to reboot twice after updating. So if anyone is not seeing the fix try a restart.
After updating to windows 10 (1607), I find that the clock speed of the CPU keeps to be 2.92GHz when plugged, and to be 2.47GHz when using battery. My surface pro 4 has a core i5 CPU. It seems strange because the clock speed of CPU should change with the workload in the Task Manager. Does anyone have the same problem?
You are welcome :). Hope MS to release the offical fix as soon as possible
Thanks for the link to the other thread. I downloaded the registry fix and applied it. It appears to be working correctly now. Have rebooted 4 times already and it survived each reboot. So this works for me. I have a SP4 i7.
Very appreciate the assistance and advice from all on this thread. Thanks.
It solved for me. sp 4 i7
It seems a regedit issue, I got an experimental fix from here(https://www.reddit.com/r/Surface/comments/4wfish/progressfix\_for\_the\_anniversary\_update\_cpu/) and it works fine until now, mine is surface book i5/dgpu/256g, hope it works for you
