bluethooth mouse breaks wireless connection
2013-07-23T16:05:01+00:00
I originally posted this here: http://answers.microsoft.com/en-us/windows/forum/windows8_1_pr-hardware/wifi-keeps-dropping-on-my-surface-kills-bluetooth/96faf92c-41af-4611-b5c2-c52702a3f241
Anyway, after a few reinstalls. I still have the same issue on my surface pro. When I go a few days without using my Microsoft Sculpt comfort Mouse, I have no problems. When I do use it, I get a total breakdown of wireless connections.  First my mouse stops responding. Then wifi drops, normally theres a lag before I see it show up on the wifi icon in the system tray. When I click it, it shows 'No connections are available', followed by 'troubleshoot' The only fix is to reboot, which it won't ever do properly after this error. I always have to hold the power button down and do a manual reset.
I also have random times when the Bluetooth goes out but comes back on. This can take about a minute to happen. When this happens, the wifi stays on.  I also have a lot of lag in the mouse while downloading/streaming anything from the internet.
Obviously this is Windows 8.1, running on a Surface Pro, using a Microsoft Sculpt Comfort Mouse.
Hopefully this gets fixed soon!
Kevin
    2014-12-24T06:45:01+00:00
    Thanks, I'll give that a try. I was hoping to be upgrading soon, so wasn't sure if it would matter anymore, but it's good to know regardless, as by the sound of it, a lot of devices can experience this.
    2014-12-22T18:11:13+00:00
    I believe that dvice broadcast in the range of  5.15 to 5.25ghz You should be able to go in to your settings and change the channel to a different one then your router. I can't remember for the 5ghz side but I think the channels need to be 3 or 4 channels apart. So if you have the mouse in channel 1 you would want the router on channel 4 or 5. Better to set the mouse in the middle because most routers will default to the lowest or highest channels. IF your router broadcast bellow/above the mouse range you can just set your router to broadcast outside of that range and it shouldn't be an issue
    2014-12-22T12:37:19+00:00
    This also happens for me on a Dell 13 laptop/tablet.   I had to stop using the MS Sculpt Comfort Mouse as when it was on it killed my network connection.  See complete story here.
    2014-08-26T23:37:24+00:00
    It isn't anything Microsoft can fix if it is the signal. That is the router and the Bluetooth frequency being in a close range band. What fixes it for you? Can you change the mouse frequency or Bluetooth frequency?
    Microwaves and wireless telephones use the same range too.
    2014-08-26T22:38:02+00:00
    This isn't just a surface pro problem, I have an identical problem on my HP laptop running Windows 8.1, once I turn off my sculpt comfort mouse my wifi returns to normal straight away ! For some reason the wifi and Bluetooth just cannot run simultaneously ? I cannot believe Microsoft haven't found a solution to this problem. Has anyone found a work around other than changing the wifi channel / rolling back to windows 8.
