2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-24T12:30:18+00:00
    In this case, it was by closing the cover (I had to run to a meeting). Thinking about it now, that's the only time it ever does this. I should be more mindful of putting it to sleep from the menu for now, I guess.
    2016-02-24T00:58:56+00:00
    I have the latest updates installed, but my Surface Pro 4 still heats up and drains its battery while asleep.
    How do you put the SP4 to sleep?  By closing the type cover, or from the Start/Power menu?
    2016-02-23T23:46:21+00:00
    2016-02-23T07:48:50+00:00
    Got surface book last week..did this yesterday..today 5 hours of nothing more than a word document and wi fi..and not non stop and battery at 17%. What next?
