2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-20T05:21:02+00:00
    I installed what came through via Window Updates. Is this different, and if so, how? The update that came through yesterday made no difference. It's still 16% GPU / 12% CPU. About 1500 mW drain per hour, or roughly 4%. What should we be seeing?
    2015-11-20T03:25:33+00:00
    The file download repeatedly fails!
    EDIT:  okay it downloaded but when I run the MSI file the log shows no drivers are available or installed
    2015-11-20T02:27:28+00:00
    Please install the new updatethat has been released yesterday and let us know if that resolves the issue.
    2015-11-19T15:48:59+00:00
    I updated too, and did not see any difference. Still 1700mW consumption.
