2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-18T11:36:21+00:00
    This is just a "Me too" post - SP4/i5/8G/512G, getting 11% drain per hour on sleep. It was about 5% before TH2.
    My big offenders are WP sync and a USB driver (both 70% active, but not in the same sleep session), but the wifi, CPU and GPU are all in there as well at ~20%.
    I've turned off connected sleep in the registry, so we'll see how that affects life later today.
    2015-11-18T01:23:14+00:00
    Exactly the same issue here. Before TH2 I could get ~700mW drain during a 2 hour sleep session. And now I just got a 1600mW from a 5 hour sleep (I disabled hibernate first). This is unacceptable.
    Most of the time the top offender is Intel HD Graphics, which seldom appeared in top 3 before TH2. The active time is amazingly stable around 15%. Besides, I usually have high activity from Marvell adapter as well and it is actually sending and receiving data. This is quite confusing since no matter how I change the related wifi settings, it still persists.
    2015-11-17T17:14:29+00:00
    Having this exact same issue, seem to be very wide spread.
    Microsoft has lied about this...during the Surface Keynote Panos Panay specifically stated that the Surface Pro 4 and Surface Book have no battery drain during sleep, when it clearly is not the case.
    2015-11-17T17:10:37+00:00
    I can duplicate those same numbers. 16% for graphics, and 12% for CPU. Doesn't matter how long it is in CS, 30 minutes, 1 hour or 2 hours. After the November update, the top 2 offenders are always graphics (16%) and cpu (12%).
