2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-11-17T16:18:10+00:00
    It would be nice if someone from Microsoft on here could acknowledge these issues with the sleep state, both the battery drain and the device refusing to wake up after a long time asleep. We have paid a lot for these devices, so is anyone reading these threads or are we just being ignored here?
    2015-11-17T16:07:28+00:00
    Just to follow, this is my connected standby session from last night, the two hours before it slips into hibernate  (essential due to me having an additional issue where the SP4 won't wake if left for many hours in CS).
    My SP4 128/4 has same problem waking from hibernation after I put it into Sleep Mode previous night. I can't even find out how to have the option of hibernation as its not available on the power button menu.
    Think I'll just have to turn it off at night till MS come up with a solution!!!!
    Going to see the MS sales guy I bought it from this Friday so it is flagged for solving.
    2015-11-16T15:51:12+00:00
    Same here. I did a clean install from the SP factory image on a USB stick, and then applied the windows updates. Note - the reason I chose to do a clean install from the image is so that I wouldn't lose Drawboard PDF. A Win 10 ISO doesn't include it, for free anyway. Drawboard comes for free with the SP 4 devices.
    Anyway, my first CS session only showed 550 mW used the first time. I was excited for a short time. However, all subsequent CS sessions after that use about 1500 to 1600 mW, and consistently, it's 16% for GPU and 12% for CPU.
    I'm very curious to hear what MS has to say about this.
    2015-11-16T10:48:57+00:00
    Hi everyone,
    did the clean install with an ISO-USB stick last night (TH2) and just installed the SP 4 Pro drivers.
    Unfortunately, the battery drain remains.
    I thought with SP4 I'd get a product with perfect software/hardware integration... it really is annoying to realize that SP4 is no better or even worse than any other Windows computer that suffers from bad firmware, bad drivers and overall bad integration with the operating system.
