2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2017-12-08T13:40:16+00:00
    2017-12-06T20:17:12+00:00
    My sp4 get very hot and drain the battery very fast
