2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2017-04-28T20:05:29+00:00
    As someone who had this issue for the majority of the first few months of initial ownership (I was a base model early adopter) I've no longer had the "hot bag" issue, as we began calling it, since new firmware was released for both the SP4 and SB over a year ago. For the past year, I havent had any further hot bag issues, and many I know who own these same devices dont either. I would contact Microsoft for a possible replacement or for further diagnosis. Good luck!
    2017-04-28T16:14:33+00:00
    Hiya Kimberley
    Turn off windows Hello as described in my previous post along with others. It worked for me, now my Surface pro barely gets warm and the battery life has nearly doubled.
    Hope it works for you too
    2017-04-28T04:03:33+00:00
    HI There Josh,
    I have recently purchased the Surface Pro 4, i5 256GB and I seem to be having similar problems to the gentleman below, where my Surface heats up to quite a hot temperature and the battery does not last long on the device at all.
    The Surface was only brought less than 2 weeks ago and is up to date on all the software.
    Is there anything that I can do?
    Many thanks
    2017-04-07T13:28:42+00:00
    It doesn't work.
