Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-09-28T02:28:38+00:00
    I don't find the back of my Surface warm at all when it's been shutdown. But I still lose about 4-5% per 24 hour period during a complete shutdown.
    So I tried another test, for kicks and giggles, by resetting my Surface. Then I did a test by doing a full shutdown. Unfortunately, it made no difference. It still lost about 5% in a day.
    Now, the last thing I'm trying is shutting it down with the keyboard detached. Read somewhere that it could make a difference so we will see.
    Mine is losing 4% per hour and having a warm SSD side.
    2018-09-27T20:03:00+00:00
    2018-09-27T02:11:03+00:00
    As already posted,  the issue was from day one of purchase, they took almost 11 months for replacement and that too reurned original without any repair.
    When I contacted them,  they stated that the charger is defective (do not they read the complaint ?, if so why they collected the surface for repair) . The charger is alright.
    When I explained the problem again , they offer replacement again now only one month warranty is left over,
    They refused to extend the warranty  , even though they took 11 months and returned without solving the problem and I could never use except diagnosis under their guidence
