I turn the Surface off with the ShutDown option in the start/stop menu, not sleep.
Have you checked the Events logs?
I don't know how to do that but will chase it up.
You mentioned in an earlier post to do a powercfg/SystemPowerReport, which I've done. I've copied part of the report here.
Line 5 is where I shut down the Surface at 8am, Tuesday.
Line 6 and 7 is where I turned it on/off to check battery drain after one hour.
Line 8 and 9 on/off to check drain at 4pm that day. It was at 75% after 8 hours.
Line 10 - a mystery. The Surface turns on by itself about 5pm and turns off 15 minutes later.
Line 12 I turn it on 8am Wednesday and it was totally drained and needed power cord to start up.
Lines 13 to 18 are restarts to install updates over the next half hour.
| 1 |
2018-09-15 20:14:14 |
0:00:01 |
Active |
Charge |
100% |
| 2 |
20:14:27 |
35:49:41 |
Modern Standby |
Charge |
SW: 54% |
HW: 54% |
100% |
| 3 |
2018-09-17 08:03:52 |
0:00:48 |
Active |
Charge |
100% |
| 4 |
08:04:40 |
0:00:05 |
Active |
Drain |
100% |
| 5 |
08:04:46 |
1:06:54 |
Shutdown (Hybrid) |
| 6 |
09:11:41 |
0:01:04 |
Active |
| 7 |
09:12:45 |
6:40:38 |
Shutdown (Hybrid) |
| 8 |
15:53:24 |
0:00:50 |
Active |
| 9 |
15:54:15 |
1:15:15 |
Shutdown (Hybrid) |
| 10 |
17:10:03 |
0:03:56 |
Active |
915 mWh |
3% of battery |
13,957 mW |
Drain |
| 11 |
17:15:57 |
14:38:00 |
Shutdown |
| 12 |
2018-09-18 07:53:58 |
0:11:47 |
Active |
| 13 |
08:05:45 |
0:00:12 |
Shutdown |
| 14 |
08:06:21 |
0:01:05 |
Active |
Charge |
| 15 |
08:07:23 |
0:19:50 |
Modern Standby |
Charge |
SW: 0% |
HW: - |
2% |
| 16 |
08:27:09 |
0:04:50 |
Active |
Charge |
27% |
| 17 |
08:33:18 |
0:00:12 |
Shutdown |
| 18 |
08:33:44 |
0:31:09 |
Active |
Charge |
| 19 |
09:04:51 |
0:35:18 |
Modern Standby |
Charge |
SW: 14% |
HW: 13% |
73% |
| 20 |
09:40:05 |
0:52:01 |
Active |
Charge |
95% |
| 21 |
10:32:06 |
2:49:16 |
Modern Standby |
Charge |
SW: 79% |
HW: 79% |
100% |
| 22 |
13:21:18 |
0:06:44 |
Active |
Charge |
100% |
| 23 |
13:28:05 |
0:00:00 |
Report Generated |
