Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-09-18T19:16:26+00:00
    Bottom line, this support thread has lasted for more than 1 year so far.  Many people are reporting this battery drainage issue.  Others, including myself, have documented troubleshooting steps that we have taken to try to address this battery drainage problem.  We have provided whatever information is needed, including sleep study reports.  One user had his SP4 replaced 3 times and continues to have the battery drainage problem.  Microsoft has also posted on this thread.  After ALL OF THIS, there has been NO sufficient resolution from them.  The burden is on Microsoft to address this effectively.
    I am the one with the 3 replacements.. I gave the case to my insurance company in order to sue Microsoft. Regarding to french customers laws.
    For the moment, MS refuse to answer .. it last for 2 years now
    I thought that MSdid the worth with its smartphone but they succeed making a bigger sh..  .. this product
    2018-09-18T14:17:16+00:00
    A M E N !!!
    2018-09-18T14:07:22+00:00
