Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-07-27T12:20:12+00:00
    This solution does not work.
    2018-07-27T12:18:52+00:00
    I have searched for the past 2 years on how to stop this dang SURFACE computer from bleeding the life out of itself when turned OFFFFFFFF.
    Not sleep, not freaking half aced off, BUT OFFFFFFFFF.
    I know how to turn a computer OFFFFF, and if for some reason when I select the normal OFFFF we have all used for the past 20 years on every computer we have used and it does not work (puts the computer to sleep mode), then SHAME ON MICROSOFT for changing the standard known way for doing this.
    I am POed to the point of NEVER buying another Microsoft computer EVER AGAIN.  EEEEVVVVVVVVVEEEEEEEEEERRRRRRRRRRRR.
    This is NOT a software problem, it is a hardware problem.
    Because NONE of the these solutions work.  I have tried them all.
    Dang frustrating.
    2018-06-12T17:00:13+00:00
    Hi Jean,
    thank you for your help.  I agree, its a nice product in many ways but fails totally on a basic need...battery life.
    Have a great day.
    Scott
