Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-06-11T21:15:16+00:00
    no way to fix it ..
    It seems that Ms wants to buried this problem .. maybe because it is an hardware/design issue which might imply to recall a large amount of device, maybe all.
    After 4 defective surface I gave the case to my insurance company because here, in france, you can sue a maker within 2 years after purchase if the product behave abnormally.
    after 2 winphone this is definitelly my last ms product .. never again !
    Thanks!
    Paid good money for SP4 and got bad product as same thing happens to me even though I diligently followed all of the suggestions/fixes in this forum---NOT COOL MICROSOFT!!
    What good does a "portable" device do when it has to be connected to power all of the time??
    I'd really want a replacement!  Or, I'll move over to another platform.
    Apparently, MS must be too busy with software services as a money maker to bother with hardware/devices...
    Unhappy, 25 year customer that has supported MS with lots of spending.
    Scott
    2018-06-11T19:11:04+00:00
    Thanks!
    Scott
    2018-06-06T13:58:25+00:00
    anyone find a solution to this yet??   IF not,   Please recommend a new machine please.  We have been fighting this for too long...
