Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-04-21T21:59:07+00:00
    Could not be a "windows thing" considering that the tablet is REALLY off with a shutdown command.
    Even without windows setup on the device (complete format without reinstall) , you'll have a battery drain
    The battery drain when off the problem seems to be widely spread (among other problems point out by specialized sites)  and tested with various levels of drain.
    Most of SP4 owners I talked to does not even notice their machine was affected by this default until I ask them to check.
    MS seems to pay attention to not recognised the problem to avoid a recall
    2018-04-16T19:54:19+00:00
    I think this is a windows 10 thing, the drain was occurring around 4% per hour when fully off. I disabled the consumer experience via local group policy as the sp4 was not domain joined. I disabled fast boot and all sleep modes. The critical thing I found settings cog>System>Power and sleep on the left: everything on this page should say never EXCEPT the last entry. When my pc is asleep and on battery power, disconnect from the network was set to never. This is telling the surface to stay connected to wifi even while asleep. Set this last setting to always, so it ALWAYS disconnects the wifi when the unit is off. Hope this helps some people, I am still looking for other junk like this,  but pretty sure that is the main culprit.
    2018-03-02T02:47:38+00:00
    My first surface the sreen is flickering and I sent to warranty they sent back to me a drained battery. I think they just swap other surfaces together. Now the second surface expired I cannot sent it again to guarantee. I never believe in Microsoft device anymore, I'm regret to buy this product.
