Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-02-27T17:12:03+00:00
    Mine, the 4th after 3 replacements, loose between 6 and 10% in 24h (real shutdown, command line).
    All the 3 previous have the same behavior approx.
    Different point at a large amount of S4 with defective behavior and, regarding the battery, whose battery failed at a high rate 25%
    https://www.computerworld.com/article/3252174/mobile-wireless/surface-pro-4-batteries-and-typecovers-are-dropping-like-flies.html
    Im my case, 3 replacements in a year is far more than I can accept and seems to be related .. quite impossible to trust such equipment in a mobility context.
    I also several Macs and that's true, the more recent ones drain in 60 days but in standby mode (apple advertise on this feature), not in shutdown state.
    My old  Macbook Air (C2D), stay most of the time in shutting down state  for several weeks without no drain at all, so does my MBA11 (1% drain in 3 month in fact for this one), replaced with a MB12 and used as a backup.
    My Asus UX305 ( CoreM 1st gen. ) keep a full charge during weeks without drain ..
    I work in the IT field (IT claims adjuster) and this is the 1st time I encounter such a behavior on a modern computer ..
    The surface is a very good-looking device
    This is with the large amount of glue used the only similarity with Apple,
     But definitely not a reliable product :(
    2018-02-27T11:29:49+00:00
    What i mean for no significant is that in shutdown (14h) i have no drain if i look at the percentage. If i look deeper in the Wh of the battery in 14h it loses 0.3 Wh (that's the worst case in this 10 days). My MacBook (2.5K€ computer) has a similar behavior and in my experience this kind of leak is quite normal. Whit this kind of drainage the Surface will be completely drained in almost 60 days that is a lot better that my previous Surface (3 days).
    2018-02-27T10:37:29+00:00
    Hi Giorgio,
    No significant drainage in hibernation is interesting but in shutdown no drainage at all is requested ..
    If not there is a flaw somewhere (defective design or component)
    My Surface is the only computer which behave this way .. all the others computer do not drain when shutdown
