Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-02-07T13:52:39+00:00
    I gave up hoping for a fix from Microsoft and paid for an out-of-warranty replacement. The new device shows battery drain of approx. 0.5% per hour in hybrid shutdown measured over a period of several days. So after less than 9 days, a fully charged battery would be dead while in hybrid shutdown. Will continue testing with non-hybrid shutdown, but it's already clear that this device has the same issue, just with a different severity level. I'll probably have to ask for a few more replacements and if that doesn't work I hope Microsoft refunds the fee. For anyone else without warranty it's probably better to not waste your time and you might be better off spending your money on a new machine of a different vendor.
    2018-02-06T20:54:25+00:00
    Regarding "battery changed," I don't have any information regarding this.  As to how I disabled modern standby, I did so by making the following change in the Windows registry via regedit...
    HKLM\System\CurrentControlSet\Control\Power\CsEnabled (1->0)
    Could the battery change be related to a second battery?   I know the Surface Book has two batteries but I don't know about your systems.  If it were because if a second battery, that could alter what you see regarding battery usage.
    There were some folks using that registry edit on their Dell systems to regain the sleep ability but they seemed to indicate the Fall Creator's Upgrade mess up that setting.  Now that I understand Modern Standby, I see no need to turn it off.
    2018-02-06T17:35:26+00:00
