Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2018-02-05T14:13:37+00:00
    that isn't a complete report. please upload the html file to OneDrive and share
    the link.
    >Here's my most recent battery report for everyone to see.
    2018-02-05T14:09:54+00:00
    This is a SIMPLE problem..  They just don't SHUT DOWN.  You would think Microsoft would have a solution to this by now!!!
    2018-02-05T14:05:03+00:00
    I shutdown with command line about 16:00 on 2/3.
    This morning I turned it on and ran a battery report.  Down to 20%.
    Recent usage
    Power states over the last 3 days
    2018-02-0209:17:05 Active AC 100 % 36,502 mWh
    21:40:08 Connected standby AC 100 % 36,615 mWh
    22:33:07 Active AC 100 % 36,615 mWh
    23:51:53 Connected standby AC 100 % 36,570 mWh
    2018-02-0308:00:26 Active AC 100 % 36,480 mWh
    08:13:46 Connected standby AC 100 % 36,480 mWh
    16:02:01 Suspended 100 % 36,465 mWh
    2018-02-0508:54:18 Active AC 20 % 7,372 mWh
    08:55:30 Report generated AC 21 % 7,477 mWh
    Usage history
    History of system usage on AC and battery
    2018-01-31 - - 9:44:14 14:15:23
    2018-02-01 - - 9:39:41 9:22:04
    2018-02-02 - - 13:41:36 1:01:02
    2018-02-03 - - 0:13:19 15:48:32
    2018-02-04
