Surface Pro 4 battery drain while OFF
2017-07-05T14:02:24+00:00
I have a HUGE battery drain while power off (not hibernating)  at least 5-10 percent per day.   I windows updates done.   I used to think it was because of the keyboard being attached. but I have switched to a Brydge Keyboard.  Does anyone else have this issue or know how to fix?
Thanks!
2017-08-04T04:59:28+00:00
Thanks Victor_S
Another solution I've found is to shut down the computer the old way - regular shutdown instead of hybrid shutdown.
You can use this shortcut:
C:\Windows\System32\shutdown.exe /s /t 3 /c "Full Shutdown"
  • shutdown.exe can execute the various sleed/hibernate commands, including the regular shutdown.
  • /s means "shutdown". If we shutdown the normal way, it is a hybrid shutdown (/hybrid)
  • /t 3 means after 3 seconds. If you skip this it's 30 seconds by default.
  • /c "Full shutdown" is a simple comment that will appear in various places as the reason for your shutdown.
Keep in mind it takes a little longer to shutdown this way, and it takes a little longer to start afterwards, but I think the computer doesn't keep some systems active, thus you should see almost no battery drain, even for prolonged times.
2017-07-05T14:59:17+00:00
That is a good question because the screen will be off.  Before shutting down and all programs are closed, you can do a CTRL+ALT+DEL and select the task manager and look at the processes that are still running at that moment and you may find 'something' but doubtful.
The power sub-system could also have a defect causing that as well and not actually shutting off the machine when it is supposed to be off.
The task manager may give you a clue when all programs are shut down.  If you can't find anything listed, it is possible you may need to contact customer support to get the machine swapped out.
300 additional answers
    2018-01-26T16:18:04+00:00
    I am following this as I have the same problem with my Surface Pro 4 (about 6-8% battery drain per night while off or hibernate). It is possible that I found a potential fix, at least for my case. I've put Surface into Airplane mode just before going to hibernate and during the last two nights didn't see any battery drain. I don't know will this be a permanent fix, but I hope it will.
    Cheers!
    Marko
    I wish this worked out for me, but unfortunately I have the battery drainage issue still occur after putting the SP4 in Airplane Mode and then putting it into hibernation.
    2018-01-25T09:36:25+00:00
    Cheers!
    Marko
    2018-01-11T07:19:14+00:00
    I don't kow if it's normal but in my battery report the full charge capacity is 38 mWh instead of 38Wh or 38000 mWh. Is it normal?
    Installed batteries
    Information about each currently installed battery
    NAME X910528
    MANUFACTURER DYN
    SERIAL NUMBER 47895
    CHEMISTRY LION
    DESIGN CAPACITY 38 mWh
    FULL CHARGE CAPACITY 36 mWh
    CYCLE COUNT 76
