I hear you. I've been using hibernate without any glitches whatsoever, what kind of glitches are you experiencing in hibernate on the SB in particular, And how often?
surface book battery drain while shut down
Split from this thread.
I have been noticing that when I shutdown my surface book, when I power it on the next day the battery has drained some. If I leave it off for a couple of days it will drain down from 100% to around 85% or lower.
I disabled fast startup... and then just decided to disable hibernation altogether. That didn't help.
I have windows hello disabled, but that shouldn't matter anyway since I'm shutting it down, not sleeping.
Some searching and I found a general windows 10 issue with the "Intel Management Engine Interface" driver. Some say that v11 can cause this issue. One solution that I have seen suggested is to go into device manager and in the power management tab for this device uncheck the option that allows windows to power it down to save power. I tried that and it didn't help.
Others have suggested downgrading the driver from v11 to v9 or v10, but I don't know where to get v9 or v10 of this driver that is compatible with the surface book. Anyone know if one of the downloads on Intel's site would be compatible?
So, has anyone else noticed this issue and know of a fix?
2015-12-10T19:41:23+00:00 -
2015-12-10T19:08:30+00:00 BB, thanks for the update again.
However, many users including myself find the hibernate workaround unsatisfactory because there are several glitches that occur randomly when waking up from that state, often causing the user to restart the system.
Also, even though I'm fully updated, today I had my display driver crash several times when I'm connected to two HD monitors at once using a Surface Dock. So, I wouldn't call that issue completely fixed.
2015-12-10T17:40:02+00:00 Microsoft this week fixed the crashing display driver issue found on the new Surface Pro 4 and Surface Book. The problem stems from the early adoption of Intel's new Skylake chipset, which is causing issues even for non-Microsoft PC manufacturers. One problem still exists, however, which is the sleep/standby states for these devices.
Windows Central has covered the topic before, and it can be quite frustrating. Essentially the Surface goes into standby (low power state) but not to a sufficient level. As a result, the CPU could stay active while the Surface is in transit (e.g. your bag) or just lying there resulting in a heated and battery depleted device. This sleep state issue is not universal and seemingly random.
Microsoft is aware of the situation, which should not be too hard due to the level of complaints. Now, a representative from the team has spoken on the matter in the Community Forums:
"Yes, The 'standby' battery life is an issue we are working on and have been working on. We can put the processor into a deeper sleep state than it is currently set to. We couldn't do it at RTM for a variety of reasons, power management is a very hard computer science problem to solve especially with new silicon. Currently it is not in the deepest "sleep" that it can be so there are wake events that would not otherwise wake it. We will have an update for this issue sometime soon in the new year."
The big news there is not to expect an update to address this until early next year and is rather disappointing.
For now, Microsoft says there are a few things users can do to improve things dramatically:
- Don't have websites open that are actively streaming when you close the cover or put the device to sleep
- Change power settings to disable sleep and only hibernate
The first tip is a common one. Microsoft Edge could keep sites active in the background even when on standby. Indeed, this is true even on Mobile, which is why some people experience bad battery on the Lumia 950 and Lumia 950 XL. Best bet: close out tabs with active elements until Edge and the OS are updated.
The second tip we have advocated for before. It was only with the Surface Pro 3 did we see Connected Standby support. Before this, the Surface Pro and Surface Pro 2 went directly to hibernate. We use this setup on the Surface Book and frankly it works just fine as the time to wake is a couple of seconds due to the speed of the processor and SSDs.
You can read how to change those settings on the Surface Book and Surface Pro 4 here in our guide:
How to force the Surface Pro 4 and Surface Book to hibernate to save battery
Wrap up
Microsoft has a lot of work cut out for them on their new Surface Book and Surface Pro 4. While new chipsets are problematic, it does little to alleviate concerns for those dropping $2k on hardware. Luckily with the above temporary solution users can still experience all that is great about the new Surfaces with a little tradeoff.
Source: Microsoft Community
This post may contain affiliate links. See our disclosure policy for more details.
2015-12-10T16:19:42+00:00 John,
Can we expect the power management 'fix' in January or will it take longer? Many of us are waiting with our return periods running out and we can't take that risk. Please let us know when the fix will be released. 4 weeks? Thx
I would suggest that the normal return period running out is not relevant to returning these devices. Microsoft has clearly sold a defective product, and has acknowledged the power issues while promising a fix. There is no way, ultimately, that if the fix is not delivered that customers will have to live with the defective product. Consumer advocate attorneys would love to engage if Microsoft doesn't solve the issues and yet will not accept a return, even after the "normal" return period.
2015-12-10T15:21:57+00:00 John,
