So I ran my tests over the past couple days and have mixed results. Not really any way to patch the drain of battery while completely shutdown. However, since my last charge both batteries have been in use, which is not supposed to happen. Here is what I found:
Disable Windows Hello for ~9 hours: 100%-99%
Disable Fast Boot for ~11 hours: 96%-94%
Turn On Airplane Mode Before Shutdown for ~10 hours: 94%-92%
Disable Intel Management Engine (SB wouldn't let me roll back to version 9) for ~13 hours: 90%-87%
I feel that if I waited longer with disabling Windows Hello I would still get about a 2% battery drain like the others. Therefore, none of these are quick fixes to the issue. I have a feeling if I waited 24 hours I would get about 4%-5% battery drain as well. I am on my 3rd SB. My last SB drained about 10% overnight and never lasted 10-12 hours while in light usage.
