Surface Pro 3 LGC Battery Degradation
2017-02-16T00:04:44+00:00
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
    2016-11-16T01:07:07+00:00
    You can tweet at surface support and link the thread to try and get attention to it.
    2016-11-16T00:56:03+00:00
    Hadn't seen an update or anyone posting anything for a few days and don't want this thread to die.  Microsoft, we need a fix.  It's clear the last one didn't work.
    2016-11-13T15:59:16+00:00
    never worked for me still get the restart to complete the update
    then on restart   it gets to about 90% white  in the box  on firmware update  then gives up
    i still have error code 14 on the device manager embedded controller firmware
    I can only install hardware updates ,but firmware updates  keep saying restart to complete the update
    everytime i turn the surface on it tries to update but fails everytime
    2016-11-13T15:35:49+00:00
    These steps worked to install the patch, but unfortunately the patch does not resolve my issue. Are there any other patches that will be coming out to resolve this issue?
    2016-11-12T01:02:18+00:00
    The firmware controller still has a splat after reboot.  This did not help in my case at least
