Surface Pro 3 LGC Battery Degradation
2017-02-16T00:04:44+00:00
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
    2016-11-16T22:48:51+00:00
    Okay.  My battery started working again.
    I have no idea why it started working again, but my system has suddenly been able to detect it and the battery life is back to normal.
    I guess the firmware but I cannot explain why it suddenly started working days later.
    Regardless I'm back on team surface.
    2016-11-16T13:41:40+00:00
    Jeremy,
    I have your problem exactly.  The boot time update meter gets just about through the "S" in Surface and then goes to into reboot.  The update history says that it needs a reboot.
    Microsoft is going to need to reprogram that firmware without resetting the power supply if this is going to get fixed.
    My SP3 just sits there anymore.  I've really stopped using it for everything lately.  So disappointing.
    --Chris
    2016-11-16T02:57:19+00:00
    says under problem status that there is not enough power to complete the required operation C00002DE
    2016-11-16T02:47:30+00:00
    now shows in the event log as " Installation failure: Windows failed to install the following update with error 0x8024CE0E:Microsoft driver update for surface pro embedded controller firmware. With warning Security-SPP Installation of the proof of purchase from the ACPI table failed error code 0xC004E016..
    2016-11-16T01:10:16+00:00
    I get update downloaded. It installs but when reboot happens it will get up to about 1/8 bar on the install then go to boot. when you look at it in the device manager it says it needs a reboot every time and does not show up in update history as installed... shows needs reboot.. Battery shows not installed but meter shows 100% charged.
