Surface Duo shutdown when not in use
2020-11-15T13:14:35+00:00
Hi everbody,
since about two weeks I`m a proud owner of Surface Duo and it's doing really fine.
The only topic I've found: everytime the Duo is not in use for hours (e. g. over night) it shuts down itself.
When it is in use it works proberly.
Does anyone else has such a problem?
Surface | Surface Duo | Power and battery
    2021-03-21T08:03:41+00:00
    Bug still exists after March Update.
    2021-03-19T14:22:59+00:00
    Just installed an update. The build number is 2021.207.70. Within minutes, the device has rebooted twice.
    2021-03-17T13:10:09+00:00
    This random, unpredictable, shutdown issue has been going on for months.  If it cannot be fixed by an update, I would like to figure out how to get the Duo to make a clearly audible sound whenever it shuts down.  The sound needs to be loader than the soft note emitted when the Duo is closed.  The Duo has many positive features, but it must be reliably available for incoming calls and texts for people to be willing and able to use it as a primary communication device.
    2021-03-16T23:10:44+00:00
    Just noticed the shutdown or reboots. I hope this is fixed soon. I have really liked the Duo. If not fixed, this issue will force me to consider another phone.
    2021-03-05T21:11:50+00:00
    Seems to get better since February Update. Only one crash every two days.
