Surface Duo shutdown when not in use
2020-11-15T13:14:35+00:00
Hi everbody,
since about two weeks I`m a proud owner of Surface Duo and it's doing really fine.
The only topic I've found: everytime the Duo is not in use for hours (e. g. over night) it shuts down itself.
When it is in use it works proberly.
Does anyone else has such a problem?
Surface | Surface Duo | Power and battery
    2021-04-19T15:20:37+00:00
    I'm sending back my 4th and getting a 5th device due to the random restart issue.
    2021-03-31T06:29:56+00:00
    I had the same issue. Since February Update it's almost gone. Only one shutdown a week. I didn't use the bumpers.
    2021-03-31T04:37:15+00:00
    just another thought, are you using the bumpers that came with the phone?
    I Do and mine is keeping shutting down hence my battery lasts almost a week :D
    Best regards
    2021-03-30T21:14:27+00:00
    I was previously experiencing the random shutdowns, but they have almost totally gone away.  I downloaded the latest update and did have an Android problem affecting app usage, but I was able to clear it.  Since then, my Surface Duo has been operating nearly flawlessly as hoped and expected.  I am sorry that others are still experiencing the random shutdowns.  All mobile phones should provide 100% uptime.
    2021-03-30T20:51:05+00:00
    Same issue here,
    My 2nd device, always turning randomly off when not in use.
    Imho this premium class phone should habe a better quality assurance. I don't think that this is a hardware issue.
    Device is unreliable with build 2021.207.72
    Please fix this...
