Double tap to left click and drag on trackpad
2013-10-25T13:45:34+00:00
Hello, I was trying to find a way to click and drag by using the Type Cover 2 trackpad without keeping the left mouse button pressed. Most touchpads nowadays register a rapid double click as a "left click and drag" command and, according to the documentation on Microsoft's website, the Type Cover 2 should as well. However, I tried to use the feature both in Desktop programs and UI apps with no success. How to left click and drag without keeping the trackpad's left mouse button pressed?
Edit: called the customer service, and I was told that the team is aware of the issue and that a fix is planned.
2014-04-09T01:07:12+00:00
With 8.1 update 1, type/touch cover 2 can now perform double tap-drag. All hail lord Microsoft.
2013-11-21T02:57:03+00:00
Greetings all,
The “Tap, then tap and slide one finger in any direction"  gesture to perform a “left-click and drag” is not supported in Windows 8.1 for precision touchpads such as Touch Cover 2 and Type Cover 2.
The “left-click and drag” function can be performed on Touch Cover 2 and Type Cover 2 by holding the left touchpad button down and then sliding a finger in any direction.
We’ll be updating the inaccurate information in Touchpad: A built-in mouse.
158 additional answers
    2014-08-20T22:19:51+00:00
    We are in August and this bug is still not fixed ?
    The type 2 can't provide a basic feature whereas the type 1 obviously can and where any touchpad of any laptop in the world can.
    Please WAKE UP !!
    2014-07-14T15:13:22+00:00
    Don't do that, make a video to youtube is good, just don't blend it. Give it to someone who need it, say, a poor kid longing a pc?
    2014-06-30T07:37:07+00:00
    I have a Type Cover 2 on a Surface Pro 2. I installed all updates. The double tap and drag gesture does not work. Does it have to be switched on somewhere?
    Andreas
