Surface Pro Pen pressure sensitivity is not working in photoshop CS6.
2013-02-10T14:58:36+00:00
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
2013-05-09T21:41:01+00:00
http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
352 additional answers
    2013-04-20T23:04:02+00:00
    Flash animator here, very jealous that there is a workaround for you Toonboomers. Least you don't have to worry about this anymore! Have fun!
    2013-04-20T15:44:13+00:00
    I recently went from Animate to Harmony 10.0.1, and I saw a speed boost on the desktop actually. Maybe that was just Animate not being as well coded as Harmony...I dont know I'm just guessing.
    Well good to know there is some animation software that works well on Surface Pro.
    2013-04-20T15:40:03+00:00
    Up until today I've been using Harmony 7.8 on the Surface Pro. I've loaded up some really heavy Harmony files to test it out and it's done extremely well. Harmony 10.1 is slower for some reason but I've noticed it to be slower on my desktop as well. The Surface Pro won't replace my desktop any time soon for my professional studio work but it's a perfect fit for my personal projects.
    2013-04-20T15:18:12+00:00
    Oh wow look at that, there it is in the settings in Harmony. Good looking out! How does Harmony perform on the Surface?
