http://www.wacom.com/support/drivers
Select windows 8
or use the direct link
http://www.wacom.com/feeldriver
Download the driver dated may 9th ...today.. install and
reboot.
Surface Pro Pen pressure sensitivity is not working in photoshop CS6. Was anyone able to get their surface pro to use the pen pressure sensitivity? In my photoshop settings when i turn on Pen Pressure for brush settings i see a yellow exclamation mark next to each settings which has to do with pen pressure. If anyone knows how to solve this problem please let me know.
Select windows 8
reboot.
I tested CS6 and mx 2004. It works okay for about a minute and then every brush stroke freezes up Flash for about 30 seconds.
Which version of Flash are you using?
After a long a conversation with Microsoft Tech Support I've basically gleaned that they aren't taking any responsibility for the incompatibility and place the blame on Adobe's doorstep. Especially frustrating to me is that the pen not only doesn't have pressure sensitivity in Photoshop, the brush in Flash is unusable as every drawn stroke takes 30 seconds or so to register freezing the entire program in the meantime.
The patient tech support guy was getting all of his information from this very thread.
prominently features Photoshop by name which implies compatibility - especially in light of the hoopla about the Wacom digitizer support. It takes a lot of Chutzpah to continue to promote Adobe compatibility when they admit it won't work.
On 2/12, MS promised COMING SOON. And shortly after they claimed they had a driver in testing.
Requested an alpha/beta driver with zero interest from Microsoft. All we get are canned meaningless replies now. Look for details in the coming weeks is NOT an answer.
I would like to return my Surface Pro. I bought it Feb 6th. When I was told on 2/12 that a driver was coming soon, I took that response to be honorable and in good faith kept the device. Now all requests are ignored.
