Surface Pro 2 - Surface cover telemetry driver / blank screen after putting tablet to sleep
2013-10-23T05:19:56+00:00
I just picked up my Surface Pro 2 256GB today and it ran into problems right after applying the firmware update that seemed to have been released just today on Windows Update.  I confirmed this problem was caused by the firmware update because I restored the tablet and the wireless was working fine and I applied the firmware update and that broke the wireless.
After the update, the Marvell AVASTAR Wireless Composite Device stopped working...meaning, the tablet does not recognize the wireless card.  This is confirmed by going into the Device Manager and seeing 2 unknown devices (one of them was the wireless card, the other unrecognized device I will explain in the next paragraph) When I tried running the update driver function, it tried to reinstall the driver but returned the following error.
Windows encountered a problem installing the driver software for your device
Reinstall the drivers for this device (Code 18)
I had to go the manual route and there were 2 Marvell drivers listed and one Microsoft driver listed for the Marvell card.  The 2 marvell drivers listed had exactly the same name.  However, only choosing and applying the second one worked.  So, the wireless was working again.
The other "unknown device" turned out to be something called "Surface Cover Telemetry".  However, trying the same troubleshooting process for the wireless card did not solve the problem and the devices still remains "unknown" in the device manager.  I just left it and carried on with installing my other software and apps as the tablet and the Type Cover 2 seemed to be functioning properly.
However, when I put the tablet to sleep by closing the Type Cover (while on battery power but charged up to 100%), the screen remained blank even though I opened up the cover again and tried to wake the tablet.  I knew that the tablet was still on but the screen remained blank even after I tried touching it, typing on the keyboard as well as briefly tapping the on/off button.  When I touch the Windows icon on the bottom frame of the tablet, I can feel a slight vibration and that told me that the tablet was on but the screen somehow is totally off.
I decided to do a soft reset of the tablet by holding on the on/off button for more then 10 seconds.  However, the screen only worked properly after many attempts.
My questions are, could it be that this "unknown device" that needs the "Surface Cover Telemetry" driver is causing this blank screen problem?  And if so, where can I download a driver that works?
Thanks.
236 additional answers
    2013-12-02T21:22:34+00:00
    Unpack the .zip file. The telemetry driver is located in the Microsoft\SurfaceCoverTelemetry folder.
    Doh....I had downloaded the Driver pack for the Pro, not the Pro 2.  Got it now...thanks for the assist.
    2013-12-02T20:50:04+00:00
    2013-12-02T20:16:40+00:00
    Where exactly is the telemetry driver folder?  I have unzipped the driver pack, but there is no folder specifically for the telemetry driver, and I have also looked at all the INF files and none refer to this driver.
    2013-12-02T13:50:10+00:00
    So, after I recently acquired a surface pro 2 (128G/4G) I am also facing various issues (immediately installed the FW update, so can't tell whether they were existent prior the update).
    My Surface regularly crashes when being sent to sleep, hibernate or power off regularly (Event log). All the errors are deemed Error Code 41 and link to the Kernel Power.
    I'm wondering whether this is a hardware issue or software, as most people seem to experience issues with the sleep mode, but not necessarily other forms of shutdown.
    I know there will be an update on the 10th of December, which will hopefully solve my problem, nevertheless I'm hugely disappointed from MS.
    Anyone having any input on the consistency of my power issues?
    PS: The regularly crashing display driver is not even troubling me anymore. Or the Skydrive client. Gosh, MS, this is like Vista. Furthermore, my Surface failed to install an update for Pinyin (the input system for Mandarin) due to an error which never installed successfully, yet I installed an updated version later and hid the original update. Highly unreliable.
    Sorry to hear that you have so many problems.
    Just to clarify, I only experiencing problems with my Touch Cover 2 due to 2 Unknown devices in device manager after a factory reset I did after october FW update.
    Device manager refuses me to install drivers for my touch cover 2 for some reason.
    You can't ask the Device Manager to automatically find the driver.  Instead, unpack the Oct. Driver Update ZIP file, then navigate in Explorer to the Telemetry Driver folder, find the INF, right click and select Install.
