Battery drain issue
2020-02-06T02:43:57+00:00
Hi all,
I just got a Surface Pro 7 and became a part of Surface community.
I have a quick question. How long does your Surface Pro 7 battery last?
I saw several posts and comments on the battery drain issue, but I'd like to know whether the battery problem is only to a specific model (i5 or i7), or just seen in some devices.
Because I feel my Surface Pro barely works for 4~5 hours (Wifi with google docs, or simple work, etc.) not up to 10.5 hours. On the ads, it clearly says 'All-day battery life' & up to 10.5 hours of typical device usage. I tried some recommendations from other posts, but so far no luck here.
So, I'd like to know whether you have a similar problem or successfully managed the problem.
Thanks in advance.
    2020-08-20T13:22:42+00:00
    lied..haha..i think so
    2020-08-20T12:07:06+00:00
    i buy SP7 i5 256GB last month, until now i already do 4 times  factory reset, clean install on my SP7 due to battery drain, hang after i connect to projector wireless via screambeam mini2 or using cable. last 2 day, i already call microsoft support to troubleshoot remotely but until now i still have problem with battery drain, sometimes langging on writing with microsoft pen, stress stress stress, my battery can hold only 5.5 hours. i buy batterybar pro to monitor my battery
    Big problem for me
    1. battery can hold only 5.5hour
    2. Hang when i try to connect to projector via cable or wireless (screenbeam mini2)
    2020-08-15T20:10:41+00:00
    Mine didn't improve either. I ended up taking a different approach. I searched XPS, x360 etc and "real world battery" send it's the same with brand. They and the reviewers just lie. It's like testing car fuel consumption standing still rather than driving. So if i do nothing with it, i can get 9-10 hours. If i watch films, 6-7 hours. If i work (office + web) i get 4-5. But it looks like the same for most small, powerful laptops.
    2020-08-15T19:18:00+00:00
    Same for update 2004, im getting 4 hours on battery saver w/ surface keyboard attached
    2020-07-19T20:20:21+00:00
    I don't think there's a fix because i don't think there's a problem other than a small battery and reasonably powerful components. I sent mine back for a replacement (to be fair they're very good at that), but it's the same. I'm afraid they simply lied about 10.5 hours.
