Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-21T14:05:46+00:00
    I’m also using a Surface Laptop 2.
    2019-09-21T13:51:02+00:00
    With what device? I’ll try tonight with the Surface Laptop 2
    2019-09-21T13:44:51+00:00
    Ignore my last post... I've done it!
    I rolled back to the build I was on before joining Insider. I then put my Insider setting to "Release Preview" as you suggested, and I got the 1909 build and have opted out of Insider after installing it.
    I shut down, unplugged, and waited about 30 minutes before restarting, and for the first time in weeks my PC started with a full 100%!
    I won't say that the issue is resolved until at least a few days without incident, but this is promising.
    2019-09-21T12:55:35+00:00
    Keep checking for available updates. The fix isnt in 18985.1.
    You should see
    Surface - Firmware - 9/4/2019 12:00:00 AM - 241.1.139.0
    in your pending update list.
    Make sure your insider settings is set to "Skip - Skip ahead to the next version of windows"
    I can confirm that this new firmware solved my battery issues.
    Previously I would turn my Surface off at night with 100% charge, turn it on the next morning and it would be at 75%.
    Now it stays wherever I left it...
    Surface Pro 6 running Windows Home v1903
