Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-21T16:50:14+00:00
    To be honest, I mostly use my PC on A/C power, so if everything is functioning normally there shouldn't be much to see. How about I share my reports if there are any anomalies?
    2019-09-21T14:21:06+00:00
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-21T14:16:24+00:00
    I'd love to see a battery report every day for the next few days if you have
    time to do those and share links to them after uploading to OneDrive..
    2019-09-21T14:08:37+00:00
    Welcome to the other side my man!
