Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-20T08:01:27+00:00
    Can anyone confirm that the new update really solves the problem? Any links/proofs/experiences? Thanks.
    2019-09-20T07:22:01+00:00
    Here you go Barb
    Lots of reports of this Insider Update solving battery related issues on Reddit
    Do understand it right, that this is a firmware update, that solves the problem, but needs an insider update of Win10? If yes, which one?
    2019-09-20T02:37:50+00:00
    Should be 1-2 weeks. My best guess would be before the new Surface line launches.
    2019-09-19T23:32:53+00:00
    Barb, I'd just like to say thank you.
    You've been more supportive to users experiencing this issue than any MS representative.
